Hello everybody,
I have a RT target (PXIe-8133) to which I would like to connect using LabVIEW 2012, from a laptop (windows 7).
Up to now I'am able to connect to that target using a PC (windows XP + LabVIEW 2012).
But when trying (under the LabVIEW environment) to connect to the RT target using my laptop (windows 7 + LabVIEW 2012) a popup window containing a Microsoft Visual C++ Runtime Library is displayed as follows:
Runtime Error!
Program:...iles (x86)\National Instruments\LabVIEW 2012\LabVIEW.exe
abnormal program termination
When trying to connect to the same target using MAX, the following message is displayed:
open a session as a user having authorizations on PXIe8133
user name:
password:
Whatever the couple login/password used the access to the RT target is denied and the following message displayed:
Unable to open a session.
Check whether or not the RT target is turned on, connected to the network and it is not in safe mode
I would like to know if someone has already been confronted to this problem and, in such a case, what was the solution.
Thank you in advance for your answers.
Hervend
