PXI
unknown device: pxi-5401
What you are experiencing is expected behaviour.  The first NI-FGEN driver for Windows 7 is NI-FGEN 2.7.2 however it does not support NI 5401. Please refer to NI-FGEN  2.7.2 readme file. The same applies for all the versions of NI-FGEN that came afterwards. You cannot use NI 5401 on Windows 7! To use NI 5401 you need to have Windows XP or earlier Windows versions. On Windows XP or ealier you can then use NI-FGEN 2.6 or Traditional DAQ driver to program your NI 5401.
Mikhail
RF Toolkits, Product Support Engineer
Message 11 of 19
(2,379 Views)
I have same problem... my card dont work in windows 7. I have installed NI-FGEN 14.0 and it does not work!
Message 12 of 19
(2,230 Views)
Did you read the previous post?
Message 13 of 19
(2,226 Views)
yeah!!! but its on version 14 now and it says it supports windows 7.
Message 14 of 19
(2,220 Views)
Message 15 of 19
(2,219 Views)
If you check the 'Description' section of the download page here: http://www.ni.com/download/ni-fgen-14.0/4824/en/
you will see that it states that the 5401 is not supported on Windows 7 still.  You will not be able to use this hardware with Windows 7.
Jon F.
Technical Support Engineer
Message 16 of 19
(2,208 Views)
Yeah .. i found that out after a day!!! took a day for you guys to tell me that! Thanks anyway!
Message 17 of 19
(2,203 Views)
Message 18 of 19
(2,203 Views)
The post saying that it wss no longer supported is two years old, not two days.
Message 19 of 19
(2,196 Views)
