PXI
use the NI6509 (PXI) board in dinamics
Hello everyone,
I am programming in Pyton and I would like to generate the dinamic signals with the NI6509 board of my PXI.
The signals, which I need to generate, are 24µs on 3 bits.
Do you have an example of a Pyton program for me to see?
Thank you very much.
Pierre
(922 Views)
You are not likely to get the rates you want with the PXI-6509 since it is a static DIO (software timed).  You will want something like the PXIe-6535, which can output waveforms ups to 10MHz.
GCentral
(893 Views)
