PXI
what advantages does embedded controller offer over remote controller
hi,
this is Alam from NUST Pakistan. i need to know that what is the difference b/w embedded controller and remote controller and what advantages does embedded controller offer over remote controller and how does the embedded controller interfaced with an output device like a monitor in a PXI suite?
(4,431 Views)
Accepted by topic author aLAM73
Hi Alam!
Our embedded controllers allow you to package your entire PXI system on one chassis. Essentially an embedded controller is an onboard PC with either Windows or a Real-Time Operating System installed that communicates with the rest of the PXI chassis.
An embedded controller offers reliability for test and measurement because it is all NI PXI hardware and has been tested by us to work with the rest of your PXI system. Using a remote controller across MXI can have reliability problems (PC and BIOS compatibility, etc) when connecting to the PXI chassis.
Also, an embedded controller allows for a more portable and stand-alone system that is not tied to a remote PC.
Our embedded controllers also offer many I/O connectors such as, display connectors (DVI, VGA), GPIB, Serial, USB, and ethernet. If you look at the specifications for the particular controller, you can see which ports they offer. For example, look at the specifications for the NI PXI-8109.
Have a great day!
Peter E
(4,416 Views)
