PXI
what does this mean, "cluster passing is off in type definition of 'StationGlobals"?
I"m trying to pass references back from a PXI running Labview, to TestStand.  It gives me an Run-Time Error, "
 Parameter 'HSDIO Ref out':
The type of 'StationGlobals.Instrument_Handles.HSDIO' does not match the LabVIEW cluster 'HSDIO Ref out' or cluster passing is off in type definition of 'StationGlobals.Instrument_Handles.HSDIO'
The TS container and LV cluster have the same definition, so I want to try to turn on Cluster passing, but I don't see how to do that.  Thanks for your help.
(3,628 Views)
Hi Prog Bill,
There is a knowledge base entry available on ni.com that details how to pass cluster data between TestStand and LabVIEW, including how to enable Cluster Passing.  You can access this knowlege base entry at http://digital.ni.com/public.nsf/allkb/AC41571A74D9BB46862573770082E839
(3,606 Views)
Thanks Jon
(3,588 Views)
