02-28-2018 03:00 PM
The PXI has only two ethernet ports but on NI_MAX it is showing me that it has three ports? I have attached the screenshot of the screen.
Please help!
FYI
both Host computer and PXI has ethercat drivers.
Solved! Go to Solution.
02-28-2018 07:29 PM
Did you use any Ethernet PXI card? If not, can you format and re-install the PXI?
03-05-2018 09:49 AM
Thanks for the response..
No.. I do not have any external ethernet modules connected expect ethercat.. I tried reinstalling the PXI it didn't work.. Please let me know if you have any other suggestions?
03-05-2018 10:24 AM
I unplugged the Ethernet cable from port 2 (port where ethercat is connected) and did format and reinstall 2 times.. then it is working fine now... thanks for the response..
