PXI
windows10 compatibility on PXIE8135 Embedded Controller and installation guide
we are trying to install Windows10 OS on PXIE8135 Embedded Controller but not able to boot from device. could you please check Windows10 Compatibility with PXIE8135 Controller and suggest us steps for installing Windows 10 Os.
of NI has Windows 10 image available in Online , requesting to provide details.
(2,423 Views)
Could you please confirm if you have tried the options from https://forums.ni.com/t5/PXI/PXIe-8135-OS-update/td-p/3951181
Santhosh
Soliton Technologies
(2,393 Views)
Thanks for sharing link , PXIE8135 Embedded Controller supports Windows 10 64bit OS but pre-condition is we need to install Windows 7 OS. i will try and update you.
i have Ni PXIe-1085 Chassis if we would like to remove PXIE8135 Embedded Controller and connect PXI Remote Control module to access from external PC , could you please share details and best Remote control module for PXIe 1085 Chassis.
Remote Control Module (for 1085 Chassis) ?
MXI Express Cable details ?
MXI-Express for PXI Express Module inside PC ?
(2,389 Views)
