Abstract: Explore a real-world example of industry using LabVIEW and NI hardware to rapidly transform a manual pressure testing process into a fully automated pressure test. Learn how Baker Hughes engineers met the following test challenge: any piece of iron pipe, valve, swivel union, and so on used at a customer rig site needed to be recertified as safe to operate under pressure after a job and before it was sent on to the next customer.
Track/Summit: Data Acquisiton Systems
Speaker: Travis Mahler, RDD Engineer III, Baker Hughes
Barrett Scrivner, Manger- Testing & Engineering Services, Baker Hughes
it looks like this session is linked with the wrong presentation content. See also
https://decibel.ni.com/content/docs/DOC-38504
Could anyone please update this with the correct presentation from Airbus?
Regards
StephanA
Hi Stephan, Our apologies for the confusion. We didn't received the Airbus presentation to share.
Ok. Could you then please change the descrition to the correct one from the original Airbus presentation? The above one is incorrect and just a copy of this one
