Abstract: Engineers in verification and validation as well as production test make countless oscilloscope measurements on the characteristics of analog signals. Every one of those characteristics is subject to transmission line effects, bad connections, and noise. The interfaces with your device under test, probes, cabling, and universal mass interconnects all play a role in analog signal integrity. At this session, learn about the considerations you need to make and equipment you should use to generate the best oscilloscope measurements possible.
Speaker: Ben Robinson, National Instruments, Product Marketing Engineer
