Past NIWeek Sessions
Closed-Loop Control and Real-Time Simulation With VeriStand
Abstract: VeriStand is a software environment for configuring real-time test applications that require control, simulation, and data logging. Though no programming knowledge is needed to use VeriStand, you can take advantage of a variety of NI and third-party environments to add custom functionality. At this session, get an introduction to VeriStand and learn how you can use it to create real-time testing applications, such as closed-loop control of mechanical systems and real-time simulation. Also explore the latest version of the software.
Speaker: Nicholas Keel, National Instruments, Group Manager- Real-Time Test Software
Contributors
