Abstract: If you maintain a program in multiple versions of LabVIEW, spend hours building your code in each deployment version, and then spend hours more testing each version, attend this session to learn how to automate the build and testing process to run whenever you commit to source code control. Explore continuous integration with Jenkins and LabVIEW so you can continue coding while your software builds and is tested.
Speaker: Ryan Sparks, National Instruments, Staff Applications Engineering Specialist - Embedded Systems
This presentation at NI Week had lots of useful information, but the slides has little value. Is this the presentation information that was shown?
https://decibel.ni.com/content/docs/DOC-43639
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
