Advanced Combustion Engines: Enabling Complete Engine Control and Test
Track/Summit: Transportation Summit
Session ID#: TS2296
Abstract: Examine the rapid control prototyping (RCP) and testing of a heavy-duty multicylinder compression ignition engine using NI Powertrain Controls (Drivven) products. The original engine control module was comprehensively "reverse engineered" to calibrate the RCP NI engine controller. Subsequently, the DrivvenCombustion Analysis Toolkit (DCAT) was used for DAQ and combustion analysis. DCAT also provided a consolidated DAQ interface for steady-state in-cylinder DAQ along with heat release rate modeling and other important combustion metrics.
Speaker(s): Andrew Polk, National Instruments
