Diagnosing Nonlinear Time-Varying Systems With LabVIEW and CompactRIO
Track/Summit: Embedded Systems
Session ID#: TS1631
Abstract: Examine an algorithm implemented in LabVIEW that uses system identification and quadratic-programming-based pattern recognition techniques to monitor and diagnose a gear dynamics simulator under varying load and speed. You can apply this approach beyond gearboxes to other challenging dynamic systems monitoring by implementing an object-oriented programming (OOP) architecture with the Actor Framework and a LabVIEW OOP plug-in architecture for CompactRIO. Also review applications in the mobile underground mining environment and relevant networking standards like IREDES and MIMOSA.
Speaker(s): Jordan McBain, LHP Software
