Where a traditional harp instrument is played by plucking strings, this harp is played by breaking laser beams! Using a single FPGA-based PXI R Series board, analog outputs are used to steer the laser beam and to generate audio for the speakers. Digital lines are also used to pulse the laser on and off, which and separates each individual laser beam, and to take frequency measurements from a photo sensor. Even though it looks like multiple lasers, only one is actually used. The control system quickly rotates a tiny mirror that reflects the laser into each string position. The R Series board constantly takes measurements from the sensor where it performs over 40 million calculations per second to synchronize the measurements with the current mirror position and to determine which note to play. Because code is implemented in hardware on the FPGA, it runs with speed and reliability. |  |
PXI-7854R PXI-1031 NI 8105 Cable: NI SHC68-68-RMIO SCB-68
Todd S.
LabVIEW Community Manager
