Past NIWeek Sessions
TestStand Multitiered Sequence Architecture
Abstract: Discover how using a multitiered sequence architecture in TestStand can maximize the flexibility of your automated software. With the process model callbacks from a TestStand process model sequence, you can use the same process model across multiple test environments while allowing customization for those environments in a main environment sequence. In addition, the product test sequence is simplified and further isolated from the process model, so the product test sequence is dedicated to testing the product.
Speaker: Jim Kostinden, Bose Corporation, Lead Test Engineer- Software/Manager
Contributors
