Learn what a network connection manager is, why you need one in your system, and how you can construct it in LabVIEW. Also explore the technical details of the build up as well as connection protocols, management , and methods. Lastly, see how to use the API to integrate this into your own system.
Mike Bailey,National Instruments
Is there an estimation of when the code that was demo'd with this will be available? I would even be happy with the incomplete version that was presented at NIWeek.
Bueller?.......Bueller?......Bueller? Or I guess that might should be Bailey?.....Bailey?......Bailery?
I took Mike's class at NIWeek and really liked this API. Is there a way to get a copy of the code? even a prelim version?
Here is the code, I have been out of the office and then rebuilding my machine, so my apologies
Thanks Mike. No problem. I do understand especially the machine rebuild. Those always seem to come at the worst time.
Mike,
When I tried to open the network connection manager there was a missing VI. It was hunting the "Serialise Connection.vi" in the folders. I did not find it in the folder structure. I also didn't see a lvproj file. Did you have one? Not necessary just expected it.
The Serialise Connection VI is now in the ZIP file. Sorry
Thanks Mike.
Well here I am again causing trouble. I was working with the API this morning and created a LabVIEW project file to help my understanding of the API. When I did that the dependencies gave the following list of files as missing when I tried to load it:
bool2str.vi
New Blue OOPSS.lvclass
New Colour OOPSS.lvclass
New Error OOPSS.lvclass
New Green OOPSS.lvclass
New Message OOPSS.lvclass
New Red OOPSS.lvclass
New Stop OOPSS.lvclass
Return Dbl Array Class.lvclass
Return Message OOPSS.lvclass
de-serialise class.vi
de-serialise return class.vi
Green Control.ctl
Blue Control.ctl
Red Control.ctl
View Events.ctl
Also the VI, manager1.vi, has an unwired bundle by name terminal. I think I can see the proper wiring but it would be nice to know the intended wiring.
For some reason those files were dependencies under vi.lib. Now they are not and in the new zip file.
Sorry
Mike
