Past NIWeek Sessions
Using the LabVIEW Control Design and Simulation Module to Speed Up Product Development
Abstract: With reduced times for product development, developers need tools to save time and expense through simulation instead of hardware prototyping. The LabVIEW Control Design and Simulation Module helps developers simulate designs before making costly and time-consuming prototypes. The simulation models can also be used for real-time test with NI’s test instruments. At this session, a Chua’s circuit is used to demonstrate the versatility of LabVIEW Control Design and Simulation. The nonlinear random dynamic behavior shows how this module can analyze complex systems.
Speaker: Larry Detherage, Certtech, Solution Specialist
Contributors
