Abstract: What do you do when one measurement system isn’t enough? With time-based synchronization, you can expand your system across a wide area. NI has the tools to help, but understanding which tool to use for each job can be overwhelming. At this session, start with the basics of time-based synchronization and the IEEE 1588-2008 Precision Time Protocol, learn the industry-standard method to measure your synchronization, and build up to more practical examples of synchronized systems using the PXI-6683 timing and synchronization module.
Speakers:
James Blair, National Instruments, Senior Software Engineer
Alisha Pulsipher, National Instruments, Staff Software Engineer
