Phoenix LabVIEW User Group (PLUG)
Resist Rebuilding Test Systems: How to Reduce Time to Test with a Reusable Framework
Hey there!
NI is hosting a webinar this coming Tuesday, October 27 on an introduction to TestStand. If you're interested, click here to register: https://events.ni.com/profile/form/index.cfm?PKformID=0x501240abcd
Tuesday, October 27, 2020
4:00 PM - 5:00 PM
Central European Time
10:00 AM – 11:00 AM
(GMT-06:00) Central America
Building test stations is no trivial task and can be very time-consuming. In many cases, we tend to develop not only the test steps, but re-create common functions that are needed for every test systems--the sequencer, database and MES connectors, limits loading, report generation, and much more. It is time-consuming to develop the same functionality over-and-over again, and it is a nightmare to maintain. What could you do with the extra time if you could re-use functions rather than rebuild them?
Join us to learn how TestStand can eliminate redundant work, act as a common framework across all your testers, and can natively call code written in Python, C, LabVIEW, and .NET. Spend one hour with us to gain back days.
Agenda:
• What Is TestStand and Where To Use It
• Deploying Systems
• Scaling and Test Strategies
• Closing: The Importance of a Reusable Framework
(2,732 Views)
Here are some NI links from today's webinar:
Benefits of Parallel Testing
How Do I Develop Automated Production Test Systems With TestStand?
Iggy Calalang
CTA Badge CPI Badge CLD Badge
(2,694 Views)
