Power Electronics Development Center
$699 USD sbRIO-9607 12-b, 120 kS/s GPIC Academic Kits Now Orderable for Eligible Academic Users
Are you a student researcher or degree-granting academic institution? (Click here for academic discount qualification criteria.)
If so, you may be eligible to order the new $699 USD NI sbRIO General Purpose Inverter Controller (GPIC) Academic Kit!
With the NI Single-Board RIO GPIC, you can develop advanced grid-tied power electronics control systems with significantly lower development time and risk. The NI sbRIO GPIC is programmed using high level NI LabVIEW graphical programming tools that are fully integrated with NI Multisim for accurate closed loop simulation, enabling you to design and test your control algorithms on the desktop and then deploy to high performance field programmable gate array (FPGA) hardware with no knowledge of VHDL or Verilog programming.
Contents of NI sbRIO-9607 12-b, 120 kS/s GPIC Inverter Control Academic Kit
NI Orderable P/N Part Description
783816-02 SBRIO-9607, ZYNQ-7020 FPGA, 220 DSP CORES, 667 MHZ DUAL-CORE PROCESSOR, RT LINUX
153901-02 THERMAL HEAT SINK KIT REQUIRED FOR SBRIO-9607/9627/9637 AND QTY 4, STANDOFF AND SCREWS, sbRIO to PANEL, 16MM LONG, M/F, M3X0.5, SS WITH SCREWS, 8MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH
782592-01 CCA, NI 9683 GPIC Industrial Multifunction I/O for sbRIO-9607, sbRIO-9606, sbRIO-9605 only
N/A NON-INDUSTRIAL AC-DC POWER SUPPLY, 90-264 VAC IN, 12VDC OUT, 18W, 2 POSITION, CONN, MALE, MINI-FIT JR, DESKTOP USE ONLY
151733-02  Cable Assembly, CAT-5E Ethernet, Thin Profile, Shielded, 2M
N/A DVD KIT, LABVIEW RIO EVALUATION SOFTWARE (LABVIEW, REAL-TIME, FPGA, RIO), 90 DAY
N/A DVD KIT, LABVIEW FPGA XILINX COMPILATION TOOLS ,WINDOWS
N/A DVD KIT, MULTISIM EVALUATION
N/A SCREWDRIVER, NI LOGO, SLIM 100 BLADE, #1 PHILLIPS TOP
Download MANUAL, NI 9683 USER GUIDE AND SPECIFICATIONS
Download MANUAL, NI SBRIO-9607 GETTING STARTED GUIDE
Download MANUAL, NI SBRIO-9607 USER GUIDE AND SPECIFICATIONS
152834-01 sbRIO POWER CONNECTOR CABLE ASSY, MINI-FIT PIGTAIL, 2C, 12IN
141158-04 QTY 4, STANDOFFS AND SCREWS,  sbRIO to RMC, 9.65MM LONG, M/F, M3X0.5, SS, NP WITH  SCREWS, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH
141161-04  QTY 4, STANDOFFS AND SCREWS, RMC to I/F PCB, 11.12MM LONG, M/F, M3X0.5, SS WITH SCREWS, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH
141160-04 QTY 4, STANDOFFS, RMC to Panel, 29.81 MM LONG, M/F, M3X0.5, SS, NO SCREWS
141159-04 QTY 4, STANDOFF AND SCREWS, I/F PCB to Panel, M3X0.5, 4.5MM HEX,  43.36 MM LONG, M/F, SS AND SCREW, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH
153158-10 sbRIO CAN/SERIAL CABLE ASSY, 10POS IDC FEMALE TO 9POS DSUB MALE
N/A QTY 1, NUT, M3X0.5
* Note: Region-specific power cable not included. Non U.S. customers will need to add a power cord appropriate for their region.
Power Cord, 240V, 10A, Euro, Right Angle 763067-01
Power Cord, AC, Japan, 100 VAC 763634-01
Power Cord, 240V, 10A, U.K. 763064-01
Power Cord, 220V, 10A, Swiss 763065-01
Power Cord, 240V, 10A, Australia 763066-01
Power Cord, 240V, 10A, North American 763068-01
Learn More
FactSheet PDF: NI sbRIO General Purpose Inverter Controller
Frequently Asked Questions: NI sbRIO General Purpose Inverter Controller
3-Phase Inverter Research Board for NI sbRIO GPIC
NI Power Electronics Design Guide
Any questions? Respond to this thread.
Message 1 of 1
(3,808 Views)
