Power Electronics Development Center
Cannot compile VI
Everything was working fine untill this message showed up when trying to compile my codes. Can anyone please suggest a solution?
(4,311 Views)
I've never seen that error before but here is what I found. Error -61488 indicates that your project file (which is stored in XML format) may have become corrupt.
The easiest way to resolve this error is to move your FPGA and RT code to a new project. To do this:
  1. Unzip the GPIC Reference Design Code to a new location.
  2. Open the reference design project (GPIC Reference Design LabVIEW 2013 SP1.lvproj).
  3. Copy your VI(s) from your old project into the new (reference design) project.
  4. Close the old project.
  5. Recompile the FPGA code in the new project.
(3,708 Views)
Actually I found the solution minutes ago, thanks to Google! But also thanks to you. The issue is now resolved.
(3,708 Views)
