Power Electronics Development Center
How can I generate a triangular wave in MyRIO FPGA
Hello all,
I am trying to build a PWM sinal bycomparing a sinusoidal signal with atriangular wave i can see a in built function for sine wave but not for triangular wave Can abyone help me?.
(3,927 Views)
the triangular wareform can be simply generated by an up counter, if you want an asymmentrical carrier. Otherwise, you can implement and up-down counter on the FPGA to have symmentrical carrier signal.
Use smallest integer data-type that fits your requirements, FPGA resources are precious.
(3,416 Views)
