Power Electronics Development Center
How to solve time voilation problem during compilation
There are the following mistakes at the end of compilation. Is there any suggestions to solve this problem? Thanks
(4,323 Views)
It's hard to say because you didn't attach your code or provide a screenshot of the loops that are failing timing. It looks like you might have placed a non-reentrant subVI inside multiple Single Cycle Timed Loops (SCTLs). Any subVIs inside SCTLs should be reentrant so that each loop has a separate (independent) copy of the IP core.  Otherwise, it's impossible to meet timing because you can't access the same resource in multiple places at the same time.
(3,481 Views)
If you are using SCTL, what is the loop rate of SCTL? Are you using pipelining technics or not?
(3,481 Views)
