Power Electronics Development Center
NIWeek Digital Energy Summit
NIWeek Digital Energy Summit, May 23-24, 017, Austin, Texas
Co-Sponsored by Semikron and OPAL-RT
Find out more and register at: www.ni.com/niweek
All sessions are in Room 17A at the Austin Convention Center
Date
Time
Presentation By
Session Title
Session Abstract
23 May
1:00-2:00 pm
(13:00-14:00)
950
Dr Qing-Chang Zhong
Next-Generation Smart Grids: Power Electronics-enabled Autonomous Power Systems
Power systems are going through a paradigm change. A lateral system architecture and two technical routes will be presented to empower the power electronic converters existing in non-synchronous distributed generators and flexible loads to behave like virtual synchronous machines so that they can all actively regulate system frequency and voltage.
2:15-3:15 pm
(14:15-15:15)
951
SEMIKRON, OPAL-RT and NI
Live Demo: Design, Test and Deploy a Grid Tied Inverter in Sixty Minutes
In this action packed session, you'll be a live witness to the entire development process for a grid tied inverter. We'll take Dr. Qing-Chang Zhong's latest IP from IEEE paper to working Semikron grid tied inverter. Learn to master the NI power electronics tool chain from co-simulation, to rapid prototype, to deployment & HIL test using Opal-RT.
3:30-4:30 pm
(15:30-16:30)
617
Center for Power Electronics and Drives
LabVIEW RT and FPGA for Power Electronics and Drives Control Apps
Discover how to combine the benefits of the graphical programming approach, software portability, and the LabVIEW Real-Time and LabVIEW FPGA modules to develop controls in power electronics and drives applications.
4:45-5:45 pm
(16:45-17:45)
655
Viewpoint Systems
Active Front End Power Conversion! What? When? How?
Active Front End (AFE) power conversion can be a mystical technology. It promises lower harmonics, better DC bus regulation, and higher efficiency. But what is it really? Explore this technology and how you can use the NI Single-Board RIO General-Purpose Inverter Controller (GPIC) to control these devices.
24 May
9:15-10:15 am
639
SEMIKRON
A Primer on Silicon Carbide in Power Converters
Silicon carbide (SiC) is a buzzword in power electronics. Explore the basics of SiC: production, implementation, and the advantages and disadvantages for anyone interested in implementing high-speed switching in power converters. View a design example and available products for fast converter implementation.
10:30-11:30 am
729
Isolated Battery Charging Through Dual Active Bridges
Grid-tied energy storage systems are rapidly becoming popular due to the rise of distributed power generation such as photovoltaic arrays. A dual active bridge topology provides for bidirectional power transfer and isolation between the grid and the battery. This presentation will investigate controlling a DAB using the NI GPIC platform.
1:00-2:00 pm
(13:00-14:00)
945
OPAL-RT
A Smarter Grid Needs Smarter Test
As digital control systems on the grid become more prevalent and more intelligent, more thorough test is required to insure the safety and compliance of the devices being deployed. A physical test bench or a few deployed test systems is no longer enough to guarantee product stability. Real-world use cases are used to illustrate this.
2:15-3:15 pm
(14:15-15:15)
947
Oak Ridge National Lab, NextEra
Wind Turbine Control: When can you trust your simulation model?
Do control engineers put too much trust in the Park and Clarke transforms? The vector relationships between balanced three phase power are the basis for traditional control algorithms and models of wind turbine generators. Can they be trusted? Under what conditions? We compared experimental results and FPGA simulation models to find out.
3:30-4:30 pm
(15:30-16:30)
661
Siemens
Accelerating HVDC Test with NI and The MathWorks
High voltage, direct current (HVDC) is key for long-distance electric power transmission. Learn how engineers used the NI platform to implement a proof of concept for a revolutionary HVDC test circuit at record speed. Discover how to integrate a high-speed The MathWorks, Inc. MATLAB® and Simulink® model into LabVIEW Real-Time and LabVIEW FPGA.
4:45-5:45 pm
(16:45-17:45)
794
Perm National Research Polytechnic University
Developing an Energy Manager for MicroGrids based on LabVIEW
The project focuses research in the field of simulation-based optimizations and software-integrated solutions for automated electrical power monitoring and consumption control. Structurally Uni's MicroGrid Lab consists of power sources, electrical transmission lines, power source controllers, protection controllers, and loads.
Message 1 of 1
(3,774 Views)
