Power Electronics Development Center
Start-up Executable build error
I am trying to build a startup executable for the RT but I keep  getting this error. I have not used 'RT Get Memory Usage.vi' on the VI I am trying to build.  Any ideas on how to get over this?
(4,825 Views)
Hi Athapa,
Did you try the steps at the bottom of the error?  If so then I would suggest posting the problem to the disscussion forums instead of the powerdev community since it does not look to be specifically Power Electronics related.  I would do it on this discussion forum.
Also you can force recompile on the startup VI by holding down ctrl+shift and left clicking on the run button.  Sometimes I do that just to make sure that my VI is actually not broken.
Brian K.
(4,720 Views)
