Power Electronics Development Center
screws and standoffs do not match in New GPIC controller (9607)
I ordered the new GPIC controller but the screws and the standoff seem to mismatch as they do not mate. Due to this I am unable to assemble the new kit. Is this a freak incident, or am I making a mistake in the assembly of the new controller?
(5,393 Views)
Hi Athapa,
Which part number did you order?
I'm reviewing the bill of materials for the following GPIC kits that include the sbRIO-9607, and the kits consistently use M3 threaded screws and standoffs.
784491-01 - EVALUATION KIT, NI SBRIO-9607 GPIC (SBRIO-9607, NI 9683 GPIC, THERMAL, PS, ACCESSORIES, SW EVAL)
784493-01 - OEM KIT QUANTITY 1, SBRIO-9607, NI 9683 GENERAL PURPOSE INVERTER CONTROLLER (GPIC), STANDOFFS
Until recently, I noticed that some of the older GPIC kits below included 4-40 screws and standoffs.  I believe these components were not compatible with the screws and standoffs in the Single-Board RIO heat spreader/thermal kit, so it appears that the new versions of the GPIC kit with sbRIO-9607 may have standardized on M3 to resolve that incompatibility.
If you are reusing an older GPIC with the new sbRIO-9607, I could see an incompatibility between the hardware in the sbRIO-9606-based GPIC kit vs the thermal kit standoffs and screws.
782591-01 - NI 9683 GENERAL PURPOSE INVERTER CONTROLLER (GPIC) AND SBRIO-9606 (OEM KIT)
782590-01 - EVALUATION KIT, NI SBRIO GPIC (SW EVAL., SBRIO-9606, NI 9683 GPIC, PS-2, STANDOFFS, SCREWS)
Hope this helps,
spex
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(4,393 Views)
Hi Spex,
I ordered Catalog No: 784492-01.
I got 4 hex standoffs (the ones that sit between the GPIC and the controller) that aren't compatible with the ones that sit between the heat sink and the controller... and also I didn't receive the longer screws (1.5" ) that raise the complete setup.
(4,393 Views)
We recently updated all of the sbRIO GPIC shipping kits to include M3 metric standoffs and screws. Most likely you received your kit before the updates went through our system. Please email me your original NI order number along with your shipping address and phone number (email: brian.maccleery at ni.com) and I will have the missing accessories shipped to you at no charge.
Here is what is contained in the updated shipping kits, including part numbers that can be used to individually order the accessories or sub-assemblies.
784491-01 Development Kit, NI sbRIO-9607 Zynq-7020 GPIC (Thermal Kit, Power, Standoffs, Accessories, 90 Day Software) $1499
Quantity
NI Orderable P/N Part Description
1 CALL FOR PRICING CCA, SBRIO-9607, ZYNQ-7020 FPGA, 220 DSP CORES, 667 MHZ DUAL-CORE PROCESSOR, RT LINUX
1 153901-02 THERMAL KIT HEAT SINK REQUIRED FOR SBRIO-9607/9627/9637
1 782592-01 CCA, NI 9683 GPIC Industrial Multifunction I/O for sbRIO-9607, sbRIO-9606, sbRIO-9605 only
1 N/A NON-INDUSTRIAL AC-DC POWER SUPPLY, 90-264 VAC IN, 12VDC OUT, 18W, 2 POSITION, CONN, MALE, MINI-FIT JR, DESKTOP USE ONLY
1 151733-02 Cable Assembly, CAT-5E Ethernet, Thin Profile, 2M
1 N/A DVD9 KIT, LABVIEW RIO EVALUATION SOFTWARE 2015 (LABVIEW, REAL-TIME, FPGA, RIO), 90 DAY
1 N/A DVD9, LABVIEW 2015 FPGA XILINX COMPILATION TOOLS ,WINDOWS
1 N/A DEMO, MULTISIM EVALUATION V14.0 - PROFESSIONAL
1 N/A SCREWDRIVER, NI LOGO, SLIM 100 BLADE, #1 PHILLIPS TOP
1 Download MANUAL, NI 9683 USER GUIDE AND SPECIFICATIONS
1 Download MANUAL, NI SBRIO-9607 GETTING STARTED GUIDE
1 Download MANUAL, NI SBRIO-9607 USER GUIDE AND SPECIFICATIONS
1 152834-01 sbRIO POWER CABLE ASSY, MINI-FIT PIGTAIL, 2C, 12IN
1 153166B-01 QTY 4, STANDOFFS AND SCREWS,  sbRIO to RMC, M/F, M4.5 HEX, M3X9.65MM, SS, NP AND SCREW, M3X5MM, PHIL, PNHD, SS, WITH NYLON PATCH
1 141161B-01 QTY 4, STANDOFFS AND SCREWS, RMC to I/F PCB, M3X0.5, 4.5MM HEX, 11.1125MM LONG, M/F, SS AND SCREW, M3X5MM, PHIL, PNHD, SS, WITH NYLON PATCH
1 141160B-01 QTY 4, STANDOFFS, RMC to Panel, M3X0.5, 4.5MM HEX,  29.81 MM LONG, M/F, SS, NO SCREWS
1 141159B-01 QTY 4, STANDOFF AND SCREWS, I/F PCB to Panel, M3X0.5, 4.5MM HEX,  43.36 MM LONG, M/F, SS AND SCREW, M3X5MM, PHIL, PNHD, SS, WITH NYLON PATCH
2 153158-10 sbRIO CAN/SERIAL CABLE ASSY, 10POS IDC FEMALE TO 9POS DSUB MALE
8 N/A QTY 1, NUT, M3X0.5
784492-01 Academic Kit, NI sbRIO-9607 Zynq-7020 GPIC (Thermal Kit, Power, Standoffs, Accessories, 90 Day Software, $799
ELIGIBLE ACADEMIC CUSTOMERS ONLY
Quantity
GPIC OEM Kit, sbRIO-9607, NI 9683 General Purpose Inverter Controller (GPIC), Thermal Kit, Standoffs, Screws
CALL FOR PRICING. This product is available in OEM quantities only. For more information about pricing, please contact your local NI representative (https://www.ni.com/contact-us/).
Quantity
1 N/A SAFETY INSERT, NI SBRIO-9607 SAFETY, ENVIRONMENTAL, AND REGULATORY INFORMATION
(4,393 Views)
