Power Electronics Development Center
standard install sb9607 (eliminate services?)
I recently updated a project that used to run in sbRIO-9606 to an sbRIO-9607.
The project consists of a discrete closed-loop control algorithm that must run at 2.5kHz with no jitter (and the math operations of the control algorithm are executed in the processor; the FPGA is not suitable).
Now, in the new sbRIO-9607, the project fails to  meet the time requirements.
I would like to know if this is caused by the software installed in the RT target.
What software could be recommended to remove in order to release cpu resources?
Any help would be appreciated, thanks!
Diego
Message 1 of 1
(3,663 Views)
