Property Inspector Macros
Logging Build Frequency, Memory and Timing
The build dialog in LabVIEW has no information on how long the build took. Imagine if you could keep track of when was the last build, how many builds were performed, how long did each build take and how much memory was used. Property Inspector can track all these details in a single file, automatically. Just run a macro to build each of your projects
Macro: Build Project1.pi5
PI Log C:\temp\Build Logs\Build %NAME.txt
Project Build
Log Build %NAME Complete
Log Memory
PI Log
To add user notes to the log, just run the macro from the Macro Editor and add a Log line before the build with any comments
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Contributors
