Python and NI
Generate a TTL signal with BNC-2110 using Python
Hello everyone,
I need to generate a TTL signal to control an AOM(acousto optical modulator) in real time.
I got a BNC-2110 block from NI which is connected to a PCIe-card. My idea is to connect one of the PFI-channels to the 'User-Defined Signals'-BNC ports and use the output to turn on and off the AOM.
So far all other instruments are controlled via Python, so I would like to do the same with the BNC-2110.
My problem is that I am rather unexperienced in handling the 'nidaqmx'-packages. I know that I can somehow set the 'DigitalDriveType' or the 'LogicFamily' but I do not know how to actually generate an output.
I found a few examples but they are not commented, so for me as a beginner not really helpful.
I would be grateful for any advise.
Thank you very much in advance.
Lukas
Message 1 of 1
(2,937 Views)
