QControl Enthusiasts
Feature Requests
Use this discussion thread to propose features to be added to the QControl Toolkit.  This could include QControls shared in the community that should be included with the toolkit on the next release.
Vote for features you like by giving "kudos" to those ideas.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(6,493 Views)
New QControl Request: Dynamic Tree
I often share the following rule of thumb for developing UIs with tree controls and maintaining a responsive UI:
  • If your tree has _hundreds_ of items, you'll probably be fine with Defer Panel Updates.
  • If your tree has _thousands_ of items, you'll probably be fine with Add Multiple Items to End.
  • If your tree has _tens of thousands_ of items, you'll probably want to redesign your UI to only show a subset of tree items, with a separate scrollbar and a bunch of G code to dynamically populate the tree as it is scrolled and/or the UI is resized.
It's that last item that I think would make a good QControl... A tree control that displays a very large set of data, but only actually populates what you can see. It would dynamically change contents based on scroll position (probably requiring a separate scrollbar control), item expand/collapse, and pane sizing.
(6,477 Views)
Please, Can you add direct access to the QConrtol Help file in the QControl Creation Wizard dialog?
(5,661 Views)
Great idea! Add to issue tracker as an enhancement:
https://gitlab.com/QSI_Shared_Code/SharedQControls/QControlToolkit/-/issues/7
(5,648 Views)
