QControl Enthusiasts
LV crash when creating a QControl inside an auto-populating folder
Steps to reproduce:
1. Create and save a blank project
2. Create the subfolder "Test" in the project folder on disk
3. Add this subfolder as Auto-populating folder in the project
4. Create a new QControl, inheriting from Control, give it any name, change the folder to the "Test" subfolder.
6. Press Create -> Crash "DAbort 0x2A7EA578 in LVLibrary.cpp".
Using LV 20.0.1 (32-bit)
(1,715 Views)
I’ll look into it but as a general rule you shouldn’t use auto-populating folders with LabVIEW Classes.  This goes for QControls as well because they are LabVIEW Classes.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(1,704 Views)
I know, auto-populating folders are generally not recommended at all.
But I usually have an a-p "Tests" folder in my projects where I put all my "experimental" / "trash" VIs and classes, so that they are automatically stored in a separate folder without much effort.
(1,690 Views)
