QControl Enthusiasts
Question - Launch Event Handler - Asynchronous call
Hy,
I have a question to the Launch Event Handler.vi. I saw this code (image below) in the QControl Launch Event Handler and also in the Actor Framework's Launch VI. This is a general question to improve my skills. I know what this code does and how it works but I don't fully understand the reasons behind this code.
The VI is non-reentrant and the shift-register stores the reference between calls. So the VI reference is only opened once between different calls.
Is this the only advantage you have over the straight-forward implementation with opening the VI reference before the Start Async Call every time. Are there other reasons too (e.g., performance)?
Greets
Martin
(5,454 Views)
Accepted by topic author matrixx567
I have been trying to find @
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(5,429 Views)
Thank you for the answer. This was also my first guess.
Greets
Martin
(5,407 Views)
If you look in the AF launch code, there is a comment and a link to the relevant conversation.  It's for reasons of performance AND to avoid being blocked by "Root Loop", which is the problem that certain things, including the User having a menu open, block opening a reference for an async call.
(5,399 Views)
Hy,
I also found an interesting blog article about the Root Loop.
(5,344 Views)
