Quick Drop Enthusiasts
Create multiple wire labels automatically from first element of the wire
Hi all,
my first quick-drop-plugin, so i'm exciting about your feedback and ideas.
I would love to integrade them in my plugin
To install
Place the Build wire labels.vi in the <LabVIEW>\resource\dialog\QuickDrop\plugins folder. Launch Quick Drop and click "Configure", and go to the "Ctrl-Key Shortcuts" page. Configure a shortcut for this plugin (since it does not currently specify a default shortcut).
How to use
  1. Mark some wires (important the VI must be saved one time)
  2. Open quick drop (Ctrl+Space)
  3. Press Ctrl+[key], where [key] is the shortcut key you cofigured in the installation step above.
  4. The Plugin takes the Name from the next tunnel before - it can go thru Loops, Structures and so on and label it to the marked wires
The VI is saved in 2012.  I have only briefly tested it with 2013 and now 2014 , so please make me aware of any bugs.
Im looking forward to your comments.
Best regards
Lorenz
Update: VI Shoud now choose the right color also in 2014
(8,264 Views)
The color formating does not appear to work in 2014.
(4,421 Views)
Hello sjbrown,
thanks a lot for that Feedback.
Your right - I will see if I can fix....
Best regards
(4,421 Views)
