Quick Drop Enthusiasts
Insert from Clipboard
This plugin as the same beaviour of the original Insert but it add the capability to insert an element from the clipboard. It support 1 element in clipboard.
New Release : Resolve issue by inserting VI from project
LabVIEW ChampionArchitect
Message 1 of 9
(12,039 Views)
EDIT: I'm crazy this works great thanks.
Message 2 of 9
(9,316 Views)
Your not crazy ... I have corrected the problem with multiple joints.
Message 3 of 9
(9,316 Views)
I have uploaded a 2012 version
Message 4 of 9
(9,316 Views)
I hope that Darren see this and make it official for LV2015
Message 5 of 9
(9,316 Views)
Dany,
A sincere thank you for implemeting this.  Works great!
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 6 of 9
(9,316 Views)
Been using this for a while and thanks again.  One minor issue I've seen is if I drop a polymorphic VI on the block diagram, then copy it to my clipboard, then invoke an insert, instead of the polymorphic VI being inserted, the currently selected instance is inserted.  Same with the replace.
A solution is in where you check to see if the one reference from the Select List is valid, you then use the to more specific to go to a SubVI.  I added code which first sees what the class name is.  If it is a PolymorphicSubVI then read the polymorphic VI reference, and get the path of that for the insert or replace.
Message 7 of 9
(9,316 Views)
Great suggestion, feel free to update it. I don't have enough spare time to look at it
Message 8 of 9
(9,316 Views)
So I made a new version of this which doesn't rely on replacing the native insert, and supports having multiple objects in your clipboard.  I choose to make a new thread instead of updating this one, because the technique is so different that I didn't want it to get confusing with multiple attachments for new and old versions that work differently in the same thread.
Message 9 of 9
(9,316 Views)
