Quick Drop Enthusiasts
Miscellaneous quick drop plugins from SAPHIR
Here are a few Quick Drop plugins, that we developed and use every day at SAPHIR.
These plugins are the following :
  • Align & Connect : align and connect “Reference” and “Error” inputs/outputs of selected VIs.
  • Add comment : Add a pre-formatted comment on your VI.
  • Control to indicator : Switch between controls, indicators and constants.
  • Disable code : Put a Diagram Disable Structure on the selected part of code.
  • Remove Structure : Remove selected structure, keeping the visible case.
  • Set Connector Pane : Connect controls to the connector pane according to their front panel position.
You can download these plugins and have more information on SAPHIR - Toolkits
Any feedback, comments, improvement ideas will be greatly appreciated!
We hope you will enjoy it like we do 😉 !
Christophe | Armatan | Certified LabVIEW Architect
(12,009 Views)
Updated our tool to be compatible with LV2010 and later...
(7,633 Views)
Dear Quick Drop Community
I have been using Saphir Plug Ins with LV2014 for a long time. Now I jump to LV2020. I am missing the "Set Connector Pane" option associated with "Ctrl-E". This links the Controls and Indicators to the Connection Terminals based on their position.
Is there a version that works with LV2020?
When I try to copy the plugin from my LV2014 installation to LV202, it misses "Connect Control to connector pane terminal.vi", which is expected at "_lavacr\scripting tools\public\
Where i can find this library?
(5,187 Views)
Sorry for the late reply, I did not have any notification about this message...
The VI you are missing is part of the "lava_lib_LabVIEW_API_scripting_tools" toolkit you can download with VIPM.
It should work with that
(4,964 Views)
