Quick Drop Enthusiasts
QD Plugin to change autosizing of clusters
This is a QuickDrop plugin I created to quickly modify the autosizing property of all selected clusters.
It works on both front panel and block diagram. By default the autosizing is set to "Arrange Vertically".
How to use:
  1. Open quick drop (Ctrl+Space)
  2. Type in the autosize format you want
    • None : "None"
    • Size to Fit : "Auto", "Fit", "Size to Fit"
    • Arrange Horizontally : "Arrange Horizontally", "H", "Hor", "Horizontally"
    • Arrange Vertically : "Arrange Vertically", "V", "Vert", "Vertically"
  3. Press Ctrl+Z (Z for autosiZe)
  4. Any clusters that you selected will be modified
This VI is saved in LabVIEW 2013.
Stefan Lemmens
Intersoft Electronics
Message 1 of 1
(3,772 Views)
