Quick Drop Enthusiasts
Quick Drop: Class method select
Description
This quick drop functionality will allow you to place in the diagram a specific method from a class (or a library).
The methods visible for selection depend on the selection you have made in the vi where you activated the quick drop.
The selections that can be made are:
  • Class wires
  • Class methods (vi)
  • no selection (scope of the vi itself)
So if you for example select a class wire, only the methods of the type of the wire are shown. This also includes the methods of the base classes.
These methods are ordered by scope.
A double click on the method will place the vi in the diagram at the location of the selection.
A method replace is also available. This can be done by selecting the method vi you want to replace, press the ctrl-space and then the quick drop shortcut you assigned while pressing the shift key.
Installation
Copy the llb to <LabVIEW Folder>\resource\dialog\QuickDrop\plugins
And don't forget to assign a quick drop shortcut key
Requirements
Source in LabVIEW 2010
Tested with LabVIEW 2010, 2011 and 2012
I hope you'll enjoy this tool as much as I do. It will certainly increase your efficiency if you frequently use classes in your applications.
Patriek
Message 1 of 1
(6,412 Views)
