Quick Drop Enthusiasts
Quick Drop Keyboard Shortcut - Open Class
You can right click a class object and choose "Show Class Library" but sometimes, all you have is a class wire going between two nodes. You used to have to right click the wire, create a constant, and then right click the constant to show class library, but now you can just select the wire, and this quick drop shortcut will open the class.
Use:
Select class wire, terminal, constant, or control. Or select a subVI with a class terminal.
If nothing is selected, it will try to open the current VI's library.
Default Shortcut - o. (for open class)
Message 1 of 9
(10,362 Views)
I made it into a shortcut menu plugin and added the ability to operate on either a subvi terminal or a wire (LV2018).
Message 2 of 9
(7,641 Views)
Freaking awesome! Will use it and recommend it to everyone! KUDOS
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Message 3 of 9
(7,625 Views)
Is it possible to downconvert it to LV2015, to install it across other LV versions?
Message 4 of 9
(7,620 Views)
Yes, no problem. I don't have 2015 to test with though. If I recall correctly, there might be a small issue with "separating compiled code" so if the shortcut doesn't show up, you might want to uncheck that box.
Also, I was thinking that it should be possible to extend this so you can click on a wire with a type definition and open the .ctl. I'll put that on my "to do" list.
Message 5 of 9
(7,617 Views)
Message 6 of 9
(7,615 Views)
Thanks a lot!
Sincerely, kosist90.
Message 7 of 9
(7,604 Views)
Cool plugin!
What would be also nice, is to have there additional option to open Parent Class library - I guess, it'll be also handy.
What do you suggest, please? Is it possible to add it there?
Thanks a lot,
Sincerely, kosist90
Message 8 of 9
(7,597 Views)
You might want to post this plugin in the LabVIEW Shortcut Menu Plug-Ins board.
Message 9 of 9
(7,589 Views)
