Quick Drop Enthusiasts
Quick Drop Keyboard Shortcut - Wire Multiple Objects Together
Hi Darren!
I am running LV2012sp1f3.
I did a simple example with a control and an indicator of the same type.  I tried strings and error clusters.  I get the following error:
Error 1055 occurred at Property Node in Wire Multiple Objects Together.vi->QuickDrop Launch Window.vi->QuickDrop Launch Window.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Object reference is invalid.
I tried adding a Concatenate String node inbetween and it worked fine.
Great tool!
Message 11 of 31
(5,019 Views)
I just posted an updated version of the shortcut. It currently provides all the functionality I was envisioning, and it fixes the issues posted previously on this thread. Once I clean it up and add documentation, this is the version I would like to ship with 2014. Please try it out and let me know if it functions as you expect, and if you encounter any problems. Thanks for all the feedback y'all have given me so far.
Message 12 of 31
(5,019 Views)
I like this shortcut, but I've modified quite much myself.
1) I added so it ignores Value type check for empty arrays and bundlers, so I can select multiple e.g. Control Refs and a Build Array, and it just wires them up.
2) I also added the Wire-Labelling QD in the same VI, i.e. if you select just a wire, this shortcut (Ctrl-W), will add a label to the wire instead of Wire everything up.
If I only could upload my version in the comment, I might upload it on LAVA, after merging it with your new version.
Message 13 of 31
(5,019 Views)
Thanks to Charles_CLA for creating a VIP file for this shortcut to make it easier to install for VIPM users.
Message 14 of 31
(5,019 Views)
Hi, I set the this vip and try it, but I find I couldn't use Ctrl-W as short-cut~?~so, I modify new short-cut to try it. As follow, I find it only connect one line when I press my short-cut once. So, I need repeat four time to connect all cluster bundle. Could any one have the same problem??
我韃靼的來,又達達的走
Message 15 of 31
(5,019 Views)
This wiring operation isn't currently supported by the shortcut, but I'll work on adding this functionality...I agree that it would be useful.
Message 16 of 31
(5,019 Views)
thanks your reply, I know it has clear target as well, just want to try if any surprise for me, haha....
我韃靼的來,又達達的走
Message 17 of 31
(5,019 Views)
These files are 2012 anybody has the same files for 2010 or older versions.
Message 18 of 31
(5,019 Views)
Unfortunately, this shortcut is only available in LabVIEW 2012 and later.
Message 19 of 31
(5,019 Views)
Darren, this is pretty amazing.  But I ran into an error on my first test (LV2012) when I used Ctrl-Shift-W after using Ctrl-W.  The diagram was compacted by Ctrl-Shift-W but an extra (broken) wire was inserted.  Ctrl-Shift-W works fine by itself, but apparently something gets messed up if it follows a Ctrl-W.
Message 20 of 31
(5,019 Views)
