Quick Drop Enthusiasts
Quick Drop Object Shortcuts for Fuse Design System Controls
Note: This document pertains to LabVIEW 2023 Q1 and later. For the same content pertaining to "NXG Style" controls, see here.
I'm a big fan of the Fuse Design System controls in LabVIEW. So much so, that I've started using them as the default control style for new VIs that I write.
To make this easier, I have replaced the Modern controls in my Quick Drop object shortcuts list with Fuse Design System controls. My new front panel object shortcuts are in the attached text file below. Just copy the contents of this file into your LabVIEW INI file in place of the existing QuickDropPanelShortcuts entry.
(528 Views)
Thanks Darren! I am using 2025Q3 and this works as intended. Thank you!
(505 Views)
