Quick Drop Enthusiasts
Quick Drop Palette Object Shortcuts (French)
NOTE: If you are using LabVIEW 2016 or later, these shortcuts are automatically installed on your first use of Quick Drop, assuming you did not copy over your LabVIEW INI file from a previous installation. Thus, this page is only necessary if you are using LabVIEW 2015 or previous.
The attached file contains NI's standard list of Quick Drop object shortcuts in French.
Instructions:
Copy the lines from the attached text file into your French LabVIEW INI file (for LabVIEW 8.6 and later).  No LabVIEW restart is required.  Note: If you already have your own Quick Drop shortcuts configured, you will need to manually merge your existing QuickDropDiagramShortcuts and QuickDropPanelShortcuts INI entries with these, keeping in mind that the lists are sorted alphabetically by shortcut.
(5,749 Views)
Hi Darren,
I found an error in your file and in the French LabVIEW 2016 environment .
"bbn:Désassembler par nom" must be replaced by "bbn:Assembler par nom"
By the way, should be great to add some others basic translations (I added them in my own environment after my first post) :
or:OU;and:ET
Adeline <initial translater of French Quick Drop Palette Object Shortcuts>
(4,759 Views)
Thanks, Adeline! I have updated the file attached to this post with the correct Bundle By Name shortcut, and I have added the 'And' and 'Or' shorcuts as you requested. These changes should also be reflected in the default shortcuts in French LabVIEW 2018.
(4,343 Views)
