Quick Drop Enthusiasts
Quick Drop Plugin: Better Move
QD Plugin for Better Move Objects in Block Diagram
Better Move as default LabVIEW shift/move feature which move Selected Objects only by 1 or 8 pixels. This Plugin move All Selected Objects until first Wire Bend.
See Animation (click to picture to Play animation) for more details.
Select Objects in Block Diagram and Invoke Plugin by <Ctrl><Space> <Ctrl><z> or <x> or <c> or <s> and plugin will move All Objects in required direction until first wire bend.
I am using this (First-Person Shooter) Shortcuts:
  • z - move left
  • x - move down
  • c - move right
  • s - move up
Steps  to Complete
  • To install this plugin, unzip the folder into the <LabVIEW>\resource\quickDrop\plugins
  • No LabVIEW restart is required
Additional Notes
License: BSD
Version  1.0.0 - initial release
Saved in LabVIEW 2009 SP1
Known Issues
Very addictive
(16,712 Views)
I like the idea, but I'm not willing to dedicate four Quick Drop shortcuts to it.  I'd implement it with a pop-up that recieved the direction, perhaps like this:
Jim
(10,431 Views)
Thank you for your feedback.
I will change it.
I found that <Ctrl><x> is not good shortcut when you forgot press <Ctrl><space> 🙂
(10,432 Views)
For me personally, I avoid assigning QDKS to the X, C, or V keys, as users may want to cut/copy/paste text into the Quick Drop text box, and a QDKS assigned to one of these keys would prevent this.
-D
(10,432 Views)
It seems very  cool.But the function doesn't work in LabVIEW 2020.Do you have newer version?
(6,834 Views)
