Quick Drop Enthusiasts
Rename LVOOP FP Object Labels (Quick Drop Plugin)
Hi
I thought this would be a great place to share a quick drop plugin.
Cheers
JG
Description:
Contains a Quick Drop Plugin which renames a Class Member VI's Top Left and Top Right Connector Pane inputs to Class Name In for control and Class Name Out for indicator. All VI control terminal labels are aligned left and indicator terminal labels right. Addtionally the Class icon will be refreshed. If Ctrl + Shift + Hotkey is selected the operation will be performed on the entire Class. The default hotkey is Z. Use this plugin e.g. after you have renamed a class and you want to update it's labels or when you have cloned (Save As) a class.
Click here to download...
Certified LabVIEW Architect * LabVIEW Champion
(5,071 Views)
I have updated this plugin.
Check it out at the above link.
Cheers
-JG
(3,923 Views)
