Quick Drop Enthusiasts
Replace from Clipboard
This plugin as the same beaviour of the original Replace but it add the capability to replace an element from the clipboard. It support 1 element in clipboard.
New Release : Resolve issue with replacing VI from project file
LabVIEW ChampionArchitect
Message 1 of 12
(11,388 Views)
Why is the default shortcut L?  If you intend on replacing the original replace function it should probably be P.
Message 2 of 12
(8,502 Views)
Your are wright, I just change it to make it working in parallel to the original one will I debuging
Message 3 of 12
(8,504 Views)
Thanks for this plugin. I've noticed that besides replacing the original function it also leaves a copy of the new function at the origin of my block diagram. So I end up deleting this additional copy each time which reduces the efficiency. Why is this additional copy there?
Message 4 of 12
(8,504 Views)
I made the correction for this problem. Please redownload the plug in
Message 5 of 12
(8,505 Views)
Thanks for the quick reply but I think I got the old version again.It doesn't seem to work and the block diagram looks the same.
Message 6 of 12
(8,505 Views)
You should see a Delete methode at the end of the VI.
That delete the pasted function:
Message 7 of 12
(8,505 Views)
That was already there in the "previous" version but in case of a block diagram function the incoming array is empty. The case structure has "Use Default If Unwired" enabled and nothing is connected on the inside in the false-case. Shouldn't the SelList[] be outputted from this case? As indicated by the green line in this image.Replace2.png
Message 8 of 12
(8,505 Views)
I found the problem. Now you can download the latest plugin.
[Edit] : the version on my PC was working. I just forget to verify the exact version that was on the web page.
Message 9 of 12
(8,505 Views)
Got it. Thanks for the fix.
Message 10 of 12
(8,505 Views)
