07-26-2016
12:06 PM
- last edited on
04-08-2025
04:01 PM
by
Content Cleaner
I believe this is the first of it's kind. Property Inspector is a developer productivity utility that allows Quick Drop plugins to be run on multiple VIs.
The utility scans all the objects in your project, library or class. Then select the QD shortcut and select multiple VIs. Run the shortcut and a dialog ask if you want the front panel or block diagram, if shift is pressed and if any text has been entered. Each VI is opened, the QD is executed, the VI is saved and closed.
This works great for:
Align front panel controls to connect pane pattern
Clean all wires
Make controls visible
Move and Size QD Plugin
This utility was demonstrated at both the May 10th, 2016 BALVUG meeting and the May 17th, 2016 LabVIEW Architects Forum meeting.
See this feature and the other 50 features live at NI Week in booth 809Q in the LabVIEW Tools Pavilion.
