Quick Drop Enthusiasts
Should Ctrl-D on a For Loop include the "N" terminal?
It's really handy to use the Ctrl-Space, Ctrl-D shortcut to create indicators on loop tunnels (and shift registers). Take this code for example:
I can select the For Loop, and very quickly create indicators for the error, style array, and label array by pressing Ctrl-Space, Ctrl-D:
But notice that it also creates a control for the "N" terminal of the loop. I *always* end up deleting this terminal right after it's created.
So the question is, should Ctrl-D on a For Loop ignore the "N" terminal? Here are the potential changes I can think of to make in LabVIEW 2014 to address this issue:
  1. No change. The "N" control will always be created (and I'll always end up manually deleting it).
  2. Never create a control off the "N" terminal of a For Loop with the Ctrl-D shortcut.
  3. Conditionally create it or ignore it, depending on some string typed in the Quick Drop text box before pressing Ctrl-D. For the sake of coding speed, I would prefer this option just be a single character (like "f" for For Loop).
Option (3) is the safest option to satisfy all use cases, but also the least discoverable. Let me know what y'all think.
Message 1 of 10
(11,230 Views)
Screw safety, this is a development tool that has no impact on previously existing code. Option 2 all the way!
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 2 of 10
(6,437 Views)
Could you detect if an input tunnel is autoindexing?  If so, only create a control for the N if a autoindexed input tunnel is not detected.  I guess you could call that option 4.
If that isn't possible, I say you have more important things to do, so option 1.
Message 3 of 10
(6,437 Views)
While you're fixing the loops with Ctrl+D, can you make it work with just the tunnels selected? That might make changes to the "N" unnecessary. I've tried numerous times to select a tunnel on the loop and Ctrl+Space Ctrl+D with no results .
Charles Chickering
Message 4 of 10
(6,437 Views)
I have more important things to do than improve the usability of productivity features in LabVIEW that I also happen to use every day?
I do like option 4, and I don't think it would be that hard to do.
Yeah, Ctrl-D doesn't look at tunnels today. I guess it could. It should be fairly easy for me to add support for the outer (source) terminals of all tunnels...and maybe shift registers too.
Message 5 of 10
(6,437 Views)
Hey, we need some way to slow you down.  How else can one of us finally catch you?
The more I think about it, the more I like my option 4.  The only time I use the N is when I am not autoindexing an input.  So it makes complete sense.
Message 6 of 10
(6,437 Views)
If you get the tunnels working, I'd be happy to alpha test it for you
Charles Chickering
Message 7 of 10
(6,437 Views)
Ok, alpha testers, here you go. Copy this VI to your LabVIEW 2013\resource\dialog\QuickDrop\plugins folder (backup the VI that is already there in case I screwed something up). This update to the Wire All Terminals shortcut implements the following functionality:
  • If a For Loop is selected, all tunnels get constants/controls/indicators created except for the 'N' terminal, provided there is at least one auto-indexing input to the loop.
  • Including tunnels and shift registers in your selection is now supported.
  • Password protection for this plugin VI has been removed (due to a previously-private method becoming public/scripting in 2013).
Let me know what y'all think!
Message 8 of 10
(6,437 Views)
Quick initial testing looks good.  Will continue to play with it though.
Message 9 of 10
(6,437 Views)
Looks good! no issues thus far. Thanks Darren!
Charles Chickering
Message 10 of 10
(6,437 Views)
