Quick Drop Enthusiasts
Show Open VIs QD.zip
Your you Main Dialogue Window is realizable then it could remember last size (an position as well) same way as Quick Drop dialogue it does
When you could select VI icon of size 32x32 on block diagram then ....
Message 11 of 13
(718 Views)
This is great! Thanks for posting, I didn't know about the "all VIs in memory" primitive. Ganked it for another, less useful plugin.
If I get some time I might try tweaking this plugin a little. Great concept/contribution.
Message 12 of 13
(718 Views)
I am using Labview 2013 and all I get is loading *_og.vi and nothing?
fixed: installed vipm packages you mentioned above. Thanks.
Message 13 of 13
(718 Views)
