Quick Drop Enthusiasts
VI Properties Dialog Quick Drop Shortcut
This Quick Drop shortcut will open the VI properties dialog of a selected VI.  This is similar to what right clicking a subVI and clicking "properties" should do natively.
To install this simply copy the VI to the <LabVIEW>\resource\dialog\QuickDrop\plugins directory.
To run it, press Ctrl-Space and then Ctrl-V.
To modify the key combination, press Ctrl-Space, click "Shortcuts..." and then navigate to the "Ctrl-key shortcuts" tab.
Note:  This QD shortcut simply opens the selected VI's properties and simulates a "Ctrl-I" key press to display the property dialog.  If you know another way to programmatically open this window, feel free to let me know and I'll update this.
For more useful Quick Drop plugins, see the Quick Drop Enthusiasts community group.
Message 1 of 1
(9,117 Views)
