Quick Drop Enthusiasts
What diagram objects can be selected, but not have attached labels?
I'm working on VI Analyzer 2019 features, and I'm trying to improve the #via_ignore bookmark feature that was added in LabVIEW 2018 (see here for more info on that). I've encountered a scenario where you can have a selectable block diagram object, but you can't attached a label to it:
The 'blerp' constant is selected, but I can't attach a label to it, I can only attach a label to the top-level cluster constant.
Can y'all think of any other scenarios on the block diagram where you can have a selected object, but that object is unable to have an attached label?
(3,327 Views)
Darren,
I think this applies to the array datatype as well. An Element in the array is selectable but you could not add a label to it.
But I am trying to understand an use case where this might cause an issue with the #via_ignore bookmark feature. I just read about this feature. I haven't used it. I couldn't immediately think of a scenario where an element in a cluster / array might fail a VI analyzer test. Could you share one?
Sudharsan
Soliton Technologies
(3,315 Views)
That's a good example. Let me know if you think of any more.
One example is the Spell Check test. You could have a cluster constant that contains a misspelling in the label of one of its nested constants.
But more generally, any custom VI Analyzer test you write can return any object as a failure.
(3,309 Views)
