Quick Drop Enthusiasts
Wire Selected VIs
This plugin inserts selected VIs into selected wires.  Multiple VIs and multiple wires may be selected.  It does the same action as the Insert quick drop, but for VIs that are already on the block diagram.
  1. Put the attached folder into your <LabVIEW>\resource\dialog\QuickDrop\plugins folder
  2. Press Control-Space, Control-s
    1. Optionally, you can press Control-Space, Control-Shift-s to prevent the selected VIs from auto-aligning, which is the default behavior
(6,323 Views)
Works with two wires, too. Slick!
(3,492 Views)
